Simple Trace™ Operating System; No External Software or CAD Skills Required!
$2,499.00
Style
Backed by Our 1-Year Worry-Free Warranty
ArcDroid™ has a generous cutting area of
26” x 15” (660 x 380 mm) Learn More
Fusion 360 and SheetCAM and QCAD/CAM
compatible
Powerful touch screen interface.
No external PC required!
Get more out of your plasma cutter
Everything you need to get started with CNC
Compatible With:
DEAL OF THE DAY
00
00
00
X2 Large Cut Indexing System
Double your cutting area up to 48" (1200mm) wide
Description
The ArcDroid™ CNC Table Top Plasma Robot is a revolutionary tool designed for precision metal cutting. Its compact design makes it ideal for small workshops and hobbyists, yet it delivers professional-grade results. With user-friendly software and robust construction, the ArcDroid™ is perfect for a wide range of cutting applications, from intricate art pieces to industrial components.
  • Compact Design: Fits easily on any workbench, saving space without compromising on performance.
  • User-Friendly Software: Comes with proprietary software that is easy to install and operate.
  • Wide Cutting Area: 26" x 15" (660mm x 380mm) cutting area for handling diverse projects.
  • Compatibility: Works with most non-high frequency plasma cutters.
  • Community Support: Access to an active user forum and extensive tutorial resources.
How can the ArcDroid™ help me?
The ArcDroid™ can significantly enhance your metalworking projects by providing precise, clean cuts with ease. Whether you are a hobbyist creating intricate art pieces or a professional fabricating industrial components, the ArcDroid™ offers:
  • Efficiency: Reduces cutting time and increases productivity.
  • Precision: Delivers accurate cuts, reducing the need for additional finishing work.
  • Versatility: Handles a variety of metal types and thicknesses, making it suitable for a wide range of projects.
  • Ease of Use: User-friendly software and straightforward setup allow you to start cutting quickly.
  • Creativity: Enables you to produce complex designs and detailed work that would be difficult to achieve manually.
1-Year Warranty for ArcDroid™
The ArcDroid™ comes with a comprehensive 1-year warranty that covers parts and labor. This warranty ensures that any defects in materials or workmanship will be addressed promptly. Our customer support team is dedicated to providing the best service, ensuring your ArcDroid™ operates smoothly and efficiently.
Why choose ArcDroid™?
Choosing the ArcDroid™ means investing in a high-quality, reliable plasma cutting solution. With its easy setup, intuitive software, and robust community support, the ArcDroid™ stands out as a top choice for both hobbyists and professionals. Its versatility and precision make it an invaluable tool for any metalworking project, ensuring you achieve the best results every time. Plus, with our 1-year warranty and dedicated customer support, you can have peace of mind knowing your investment is protected.
Simple Trace Software
The ArcDroid™ features Simple Trace software, a self-contained system that eliminates the need for an additional computer. Simple Trace allows you to:
  • Trace Templates: Use the included tracing stylus to trace and digitize your parts or hand-made templates for easy repeated cutting.
  • Intuitive Interface: Navigate the software with ease, even if you have no prior CNC experience.
  • Precision Tracing: Achieve highly accurate cuts by tracing intricate designs with the software's advanced algorithms.
  • Integrated Operation: All file tracing and cutting operations are managed directly by the Simple Trace™ controller, simplifying the entire process.
As seen in
all you need in
one tool
plasma CNC for everyone
functional
Point to point or free hand, trace your template and ArcDroid creates a cut file instantly. Import .DXF file directly for even more flexablilty. Fusion 360, Pronest and SheetCAM compatible.
portable
ArcDroid is only 20" x 14.5"x10" and Under 35 Lbs! It fits in any shop and easily portable to job sites.
accessible
ArcDroid has a powerful glove friendly touch screen interface. No external PC required. ArcDroid comes fully assembled and ready to go right out of the box.
see how we compare
langmuir
ARCBRO SPARK
cut area
26x15
23X25
23X23
speed
215 in/m
300 in/m
236 in/m
full z-axis
thc
Torch Height Control
portable
