I have only used the machine a few times and finally got it calibrated pretty decent. I thought I would try to load a fusion 360 file for the first time. I did a couple of test runs before turning on the plasma torch and everything seemed to look okay. Hit the home button and the arm started jumping around very fast all over the place and I hit the reset button because the stop button on the screen wasn't available. Now when I turn in back on can't get it to function. Just text on the screen that says
Found outdated data
Fonts okay
config ok
language update required (optional)
Icons Update required
insert the SD card with the required files and press the reset button to update
