trying to send a file from fusion to the droid and on fusion cuts perfect with simulation but when load on the tablet has bunch extra stuff on it
Did you set Curf Width on the ArcDroid to 0.00?
I forgot to on a file once, caused extra lines.
Ya, i have Kerf Width at 0.
hmmm...bizarre. You're using the correct post processor? And same units set in post and on arcdroid? ( inch or mm)
